BUGG IN FLOWSTONE! help pls
When saving the FSM file i get an error when i save it as (SAVE AS).
It says Encountered an improper argument.
It started when i ancidently removed the system map from the left side of the FLOWSTONE.
Inside flowstone program when using it.
Also some of my files are white. not this flowstone symbol.
How do i fix this pls? i tested reninstall and everything.
- djbrynte
Re: BUGG IN FLOWSTONE! help pls
we have also tried editing the registry w/- 'RegEdit'-
no joy
It's kinda important to be running this version 3.0.8.1
--that is the v we are trying to re-install
no joy
Hi nix,
did u renamed:
C:\Users\Username\AppData\Roaming\FlowStone\
and reinstalled - then recopy the Tags and modules???
did u renamed:
