Is there any auto volume module? there makes synth not raise
Postby djbrynte » Thu Nov 16, 2017 7:58 pm
I mean im after a module there synth dont raise over 1.0 in volume so it stay at 1.0, need this very much. tested limiter still sucks.
I have distortion in synth when volume goes to high. and when i lower the volume it disapair.
i have tested diffrent clippers also limiter and tested diffrent filters. nothing helps.
So i need something that stable the volume to 1.0.
Is it possible making so the oscilators volume doesent go over 1.0? so if i raise osc 1 volume to 1 and then raise volume on osc 2 then the volume on osc 1 goes down. so its mixed somehow?
djbrynte
Re: Is there any auto volume module? there makes synth not r
Postby djbrynte » Fri Nov 17, 2017 1:16 am
SOLVED.
djbrynte
