SparkFun Serial 7 Segment Display
Postby support » Wed Jan 16, 2013 1:10 pm
If anyone's interested we have just added support for these nice little LED displays:
SparkFun LED Display LR.jpg (68.93 KiB) Viewed 24171 times
Here a test project: http://www.dsprobotics.com/support/viewtopic.php?f=81&t=1143
support
Re: SparkFun Serial 7 Segment Display
Postby trogluddite » Wed Jan 16, 2013 9:47 pm
Hmm, that does look rather handy actually.
I'm hacking apart an XBox controller to make some stomp pedals for my guitar FX (with FS acting as the Xbox->MIDI interface, naturally), but was wondering what to do for a patch number display. Looks like I just found a very simple solution! :)
Postby infuzion » Mon Jan 21, 2013 7:29 am
Hey support, why do you use all those extraneous Float, String, & Int primitives all over the place please?
infuzion
Postby infuzion » Wed Jan 23, 2013 4:42 am
infuzion wrote:Hey support, why do you use all those extraneous Float, String, & Int primitives all over the place please?
Urm, anyone? Why have inline primitives like that please?
infuzion
Postby alexalthauser » Wed Jan 23, 2013 4:53 am
Very cool! I am looking forward to using that in my next project. Could you show it hooked up to the flowboard? I am wondering if it is much easier, more complicated, or about the same.. :shock:
alexalthauser
Postby support » Wed Jan 23, 2013 1:43 pm
It's just for visual error checking whilst developing. Once running in an EXE or at GUI level they have no CPU load.
support
Postby infuzion » Fri Jan 25, 2013 4:15 am
Thanks for the reply.
I was thinking more of a memory allocation issue; don't each of those use a new pointer? & doesn't all the ins have to check for multi-line addition?
Plus, there is a file-size increase. Perhaps small at first, but adds up when you have 100s of these things. I usually just NOT make the value-primitves as throughs, & delete them right away to save space & increase readability.
infuzion
Postby support » Mon Jan 28, 2013 5:46 pm
Well yes there would be some impact in those areas but this is just a test project remember.
As you say you can strip out the excess when you're done testing.
support
Postby infuzion » Fri Feb 01, 2013 6:44 am
support wrote:Well yes there would be some impact in those areas but this is just a test project remember.
I thought it was just for testing :)
But my point is, people will use this as an "authoritative" example on how it should be done, & mimic exactly for their own files.
infuzion
Users browsing this forum: Majestic-12 [Bot] and 11 guests
