Stair Stem to midi, how?
Hello gang,
In this very simple example, what would be the best way to convert the Sample and Hold output to midi to drive an oscillator like the steps (c, d, e, f, etc. or whatever. Just an example, NOT the true notes of course)?
Many thanks, BobF....
- BobF
Re: Stair Stem to midi, how?
BobF wrote:
Hello gang,
[color=#008000]Hi Bob,
I just came across this post and I cobbled together something that might help you.
It's a start, anyway.
I'm guessing that you could extract the numerical values that you need from the ruby code LED outputs.
This would require a change in output types, etc., and since I have very limited knowledge (NONE) of Ruby code, hopefully you can do this.
Keep me posted !
ROXY
S&H Stairstep-for BobF.fsm- (263.54 KiB) Downloaded 900 times
rocknrollkat - Posts: 213
Hi again BobF,
Here's that MIDI note extractor for you !
My first idea doesn't give you the MIDI notes, 0 thru 127, this one DOES !
And it's Dead Simple !
Let me know what you think,
ROXY
ROXY
S&H Stairstep-for BobF-2A MIDI Note Extractor.fsm- (146.63 KiB) Downloaded 898 times
Thanks rocknrollkat,
I may get back to this as time permits.
Later then, BobF.....
- BobF
Sure thing, Bob !
ROXY
ROXY
