him im trying to get vocal shape waveforms need help pls
Postby djbrynte » Fri Feb 02, 2018 9:23 pm
Is there any good images of vocal shapes or waveforms?
also trumpets and accordions mybe saxophones to.
just images of the shape or waveform itself i tested to google for some but dont know wich one is best.
pls help :)
im trying to design my own shapes in line editor :P
also trying to get perfect waveforms for melbourne bounce basses.
https://www.youtube.com/watch?v=_J3SfvG-V_U
it sound so pounchy and mybe FM? just need shapes of good waveforms for this kind of sound.
djbrynte
Re: him im trying to get vocal shape waveforms need help pls
Postby Spogg » Sat Feb 03, 2018 10:23 am
I’m currently working on a project which can create waves but can also extract harmonic series from sound clips, using an adjustable grain player for the source.
The series can then be edited as needed to trim the results. It’s working, but of course the results depend on getting good sound clips (not single waveforms) of what you want to reproduce. The idea is to provide waveforms for cross-fade morphing wavetable synths, and it will save waveforms as txt or Wav.
It will also feature a wave-draw system with a bi-directional adjustable smoothing filter which is also working.
So… watch this space!
Postby djbrynte » Sat Feb 03, 2018 3:13 pm
Ohh fkin cool bud.
djbrynte
Postby Wassaka » Sun Feb 04, 2018 4:44 pm
Hi djbrynte, if you are trying to do leads with vocal, maybe the better option will be use a sampler. The waveform for basses in melbourne bounce normally is a kick resampled, but you can also do it with a sawtooth and some effects like EQ.
Wassaka
Postby djbrynte » Sun Feb 04, 2018 4:55 pm
ok cool thanks then i know :)
djbrynte
