clear audio at presetchange
Postby Nubeat7 » Mon Feb 05, 2018 1:05 pm
hallo, after this was asked in the general section here is an example of how i avoid clicks, hanging notes or other audiotroubles while presetchange, specially in complex schematics where presetchanges could need up to 1 sec or more.
how it works:
when a programchange happens a trigger gets sent to the clear audio module right before the audio output and the new preset nr is holded on a sample and hold, in the output module the volume is faded to zero and clear audio is triggered which kills all audio activity, after this a trigger is sent to the presetmanagers sample and hold and the presetchange finally happens.
take care that the trigger from the output module is connected correctly with the presetmanager! if you do this wireless everything needs to be on the right level!
clear audio.fsm
(6.85 KiB) Downloaded 1170 times
Re: clear audio at presetchange
Postby Spogg » Mon Feb 05, 2018 1:37 pm
Very nice solution!
Postby djbrynte » Mon Feb 05, 2018 2:03 pm
very good but are bit advanced :P
djbrynte
Postby Nubeat7 » Fri Feb 09, 2018 2:41 pm
it not that complicated, there is just one module to add inside the presetmanager, right after the midi-presetchange, and one right before the audiooutput.
Postby djbrynte » Fri Feb 09, 2018 6:10 pm
Can you pls show me an image how to set it up :P you know i have dyslexia mate :D would be so nice of you if u do :)
djbrynte
Postby djbrynte » Fri Feb 09, 2018 6:23 pm
i think i solved it 100% thanks man. but there is one little things its still little click. not much but very little on some presets :)
djbrynte
Postby djbrynte » Fri Feb 09, 2018 6:51 pm
must have connected it wrong somehow?
I removed DC blockers and its much better just some little clicks but can i get rid of those?
djbrynte
