Method for pan polys voices?
Postby Tronic » Thu Feb 07, 2013 3:15 pm
What better way to give pan to polyphonic signals?
What I want to achieve is:
for each new voice added, assign the pan (with a sort of step sequencer pan).
1. voice pan 15% L
2. voice pan 40% R
3. voice pan 04% L
and so on
Any suggestion is welcome.
Tronic
Re: Method for pan polys voices?
Postby chackl » Thu Feb 07, 2013 3:34 pm
Well - yes this is possible ;) - But you have to identivy the notes ;)
Take a look at my schematic i crated 2009 - the unison MIDI to POLY.
There you'll find such a pan module.
Regards
Unison_Midi_New_asym_alpha.fsm
Unison MIDI to POLY
(82.24 KiB) Downloaded 1473 times
chackl
Postby Tronic » Fri Feb 08, 2013 6:34 am
thanks chackl
a great job, but I would not be linked in any way to the green,
though now perhaps the timing of the ruby you might have better results.
I will try an alternative.
Tronic
Postby chackl » Fri Feb 08, 2013 8:18 am
there are no timers and de-treaters inside this module.
This means this module is time-stable eaven if no ruby is used ;)
chackl
Postby digitalwhitebyte » Sat Feb 09, 2013 4:57 am
There are two examples of how to achieve some of the ways to pan the voices poly.
I used the Voice Tags midi, so as to have an index of all the notes you play,
in one example I used them to read a linear mapping that spreads the pan over the entire keyboard,
such as a stereo recording of a piano.
In the other example, I utilized an alternation of the pan, for each note played,
with the ability to adjust how wide is the pan.
Both examples send a pan control to the code pan module that performs the panpot.
I hope can be useful.
PolyPan_DWB.fsm
(41.06 KiB) Downloaded 1522 times
digitalwhitebyte
Postby chackl » Sat Feb 09, 2013 11:24 pm
Well - nice idea to use the Voice Tag index ;)
I did the unison poly module in times of SM when ther was no voicetag. Schould be easyer to calculate now - i try to get a look on that ;)
Regards
chackl
Postby Tronic » Tue Feb 12, 2013 2:02 pm
Yes, thx DWB :)
Tronic
Return to DSP
