DS Out dont open
DS Out dont open
Anyone can help ,this program is all new problems . Now direct sound don't open suddenly ,only Asio work
ChrisPap - Posts: 20
Re: DS Out dont open
We need a lot more information Chris!
Thnx for support Spogg ,look the pic ,I cant work anymore with direct x device, only with asio
- Direct x don't open
- 2018-05-15 (2).png (46.04 KiB) Viewed 16792 times
OK...
First question: Has it ever worked with DirectSound?
always I work with direct sound ,but and asio ,after setup to my pc, last April Microsoft update start the problem .Direct sound driver don't work with this program in my pc. No background app running ,only FS run and again I have problem with DSout ,can't play
It may be that the Windows update was incompatible with your sound driver.
What Windows version are you running?
Have you tried to download the latest drivers for the audio interface ("soundcard")?
EDIT: I just noticed you have SONY TV selected. This may need its driver updated.
SONY TV support Dx don't have problem, is the hdmi .DS is the default driver in flowstone and can't open to listen audio
The most samples from the forum they have as default Ds out .Now if I want to listen some new vsti need to remove Ds out and add asio ...and many clicks to unblock the program
- ds don't work
- 2018-05-15.png (37.06 KiB) Viewed 16774 times
I still think it may be a driver issue. Did you update your sound driver for the DS that doesn't work?
Are you on Windows 10?
Thnx! again for help Spogg .I use win10x64b all software and hardware have the last update's. Windows DirectX stop working with flowstone all ver. to my pc, after the setup of April windows update . Big update with many modifications insite
ChrisPap wrote:Thnx! again for help Spogg .I use win10x64b all software and hardware have the last update's. Windows DirectX stop working with flowstone all ver. to my pc, after the setup of April windows update . Big update with many modifications insite
You are not the only one with said Win 10 Update. I have no issues so far.
Maybe your DirectX installation is messed up. Install it again, and see if it helps.
