Midi note \ chord latch
Re: Midi note \ chord latch
Postby Spogg » Sat Mar 09, 2019 9:34 am
gvalletto wrote:I want to change my nickname and to add a bmp to my profile. How I do it?
You can't change your nickname I'm afraid. The only way is to create a new account. Then you could always add a signature which says who you were before.
To add an image:
    Go to User Control panel
    Profile
    Edit Avatar
Then you can Browse to your image and upload it. This image can be changed at any time.
Postby gvalletto » Sat Mar 09, 2019 7:08 pm
Thanks Spogg!! :)
gvalletto
Midi note chord latch
Postby Henryenaxy » Sun Mar 17, 2019 3:27 pm
How do I change what MIDI note AD output ?
When I play the Cymbal I hear Hi-Hat and when I play Hi-Hat I hear Cymbal in my DAW ?
Henryenaxy
Postby gvalletto » Tue Mar 19, 2019 1:44 am
Try replacing your drum synth by another one to see where is the problem.
Also try to replace your drum synth by a melodic synth, like a piano. If you play the correct notes, then the problem may be in the drum synth. Some drum synths bring non standard assignation.
gvalletto
Postby MichaelBenjamin » Sat Mar 23, 2019 11:48 pm
Last edited by MichaelBenjamin on Mon Sep 21, 2020 9:56 am, edited 1 time in total.
MichaelBenjamin
Postby trogluddite » Sun Apr 14, 2019 8:10 pm
I've now posted a "MIDI Hold" module which can handle three kinds of MIDI sustain/note-latch. It's in my "MIDI Helpers" schematic which you can find <here>.
Postby gvalletto » Tue Apr 23, 2019 8:57 pm
Thanks Trogluddite! You are a genius!
gvalletto
Postby Matth23u » Tue May 07, 2019 5:50 am
That's about the same thing that i'm trying to achieve! That's great, i'll try your version, i made a thread about my version but it provokes "c++" crashes in FL...
Matth23u
Users browsing this forum: No registered users and 51 guests
