LA School Esquire Limiter
Postby wlangfor@uoguelph.ca » Mon Apr 29, 2019 4:01 pm
Hi all, worked late into the night making this beast. It's not a Beta; But a working example to learn from. I plan on making a final version and I think there could be some optimizing.
max 3% CPU, I believe it could go down to 1.8?
Here are the images (click for full):
EDIT: New version 1.3 posted.
Changelog (1.3)
+ Better Logo
+ Named Presets
Changelog (1.2)
+ Better math (Now Using Ruby);
+ Peak calculation using slide and line primitive
+ Rough solution for attack and release now applied
click to enlarge:
Download Schematic
https://web.archive.org/web/20190501220351/http://dsprobotics.com/support/download/file.php?id=8686
Download Knob File (Now added to Knobman Gallery!)
https://www.g200kg.com/en/webknobman/gallery.php?m=p&p=1445
Download VST on KVR:
https://www.kvraudio.com/product/la-school-esquire-limiter-by-king-oz-records
Last edited by wlangfor@uoguelph.ca on Wed Sep 04, 2019 2:52 pm, edited 9 times in total.
My youtube channel: DSPplug
Re: LA School Esquire Limiter
Postby wlangfor@uoguelph.ca » Tue Apr 30, 2019 2:45 pm
Updated to 1.1; Changed the math so that the calculations are almost finite. I also removed some superfluous personal touches. This was made for a personal project.
(I'd removed some bass for asthetics, I may do the same but in a new way that is non-destructive).
BTW, I found a good reference in Ruby that allows these calculations for attack and release as follows:
(1-Math:E**(-1/(48000*250)));
And I wish to make a primitive derivative.
Please post a solution if You are aware of the translation. I will of course try to do that on My own otherwise.
Postby wlangfor@uoguelph.ca » Sun May 05, 2019 7:44 pm
This limiter is now added to VST4Free, it was made in association with them officially.
Here's the link to that:
http://vst4free.com/index.php?plug-ins=Mastering/Strip&l=0
and here's the link to the flowstoners.com website's section with the schematic for You to download :)
http://flowstoners.com/flowmates
Postby wlangfor@uoguelph.ca » Mon May 06, 2019 3:16 pm
Here's a new track I made with this fancy new limiter:
And I updated it so it represents the final track.
Last edited by wlangfor@uoguelph.ca on Wed May 08, 2019 4:20 pm, edited 1 time in total.
Postby wlangfor@uoguelph.ca » Wed May 08, 2019 2:28 pm
New Track I am working on with the Esquire:
Postby wlangfor@uoguelph.ca » Wed Sep 04, 2019 2:44 pm
Hi all, so I have updated this limiter so that it now has a slightly nicer design (more memorable) and it uses less CPU.
Here is a link to the KVR post (click image below):
It sounds a bit nicer now, a bit like the bands 2 EQ; I avoid using the attack for bassy kick drum samples though. I'll be adding an optional HP for such dilemmas.
