Is there a way to make Waveform symbols ?
Postby Halon » Tue May 14, 2019 7:39 pm
Ive been wanting to use waveform symbols instead of the actual name of the waveform e.g Sawtooth. Could this be done in Ruby perhaps? Although i have zero experience with Ruby and coding in general.
Cheers.
Halon
Re: Is there a way to make Waveform symbols ?
Postby k brown » Tue May 14, 2019 11:45 pm
The only thing that immediately came to mind was this little waveform selector from an ancient SM schematic, the builder of which didn't identify themselves. Uses bitmaps for the waveshapes, which I don't know how to create.
Wave Selector.fsm
(15.4 KiB) Downloaded 826 times
Postby RJHollins » Wed May 15, 2019 12:21 am
I made up some graphic symbols for an EQ display ... Bell, Shelf, Hi/Low Pass, using RUBY's draw Line commands.
It was a bit clumsy to connect all the line segments [using coordinate points], but it definitely worked.
Postby lalalandsynth » Wed May 15, 2019 1:03 am
You could use bitmaps for sure.
lalalandsynth
Postby wlangfor@uoguelph.ca » Wed May 15, 2019 3:01 pm
I think a good idea would be a true type font with all of those symbols, upsize them and then save them as a .png in inkscape. There's a font for everything.
They'd be really clean looking.
My youtube channel: DSPplug
Postby Phil Thalasso » Wed May 15, 2019 4:46 pm
Hi Halon, hi everybody,
I currently am working on a set of symbols for synths, waveforms included. I can't promise when those will be finished, as I have a lot to do. I'll share those maybe in the next two weeks.
Best Regards
Phil
Phil Thalasso
Postby Halon » Wed May 15, 2019 4:47 pm
@ Kevin Brown
Thank you! :)
@Everybody else
Ive tried making waveforms in Paint, save them as bitmaps and open them up in Flowstone. The only thing that keeps me from doing that is that it looks aweful. But thanks for your input. :)
Halon
Phil Thalasso wrote:Hi Halon, hi everybody,
Best Regards
Phil
Cant wait ! :)
Halon
Postby Phil Thalasso » Wed May 15, 2019 5:00 pm
Hi Halon,
you might want to try vector graphics, as with bitmaps it will be very hard to do. If you want to give it a try, a free program with plenty of tuts on youtube would be "Inkscape".
Best Regards
Phil
Phil Thalasso
Postby Halon » Wed May 15, 2019 6:57 pm
Thanks Phil. I'll give inkscape a try.
Halon
Users browsing this forum: No registered users and 79 guests
