image dsp
image dsp
Hi every,
i'm sorry to be a very new noob with noob questions!
i would like to make some image treatement by modifying x,y pixel of a picture
but using ticker counter for x line and x column is a very slow process, is there a way to treat an entire picture and set change for each pixel without ticker ?
thanks you
thanks you
- blobul
Re: image dsp
Hello everyone,
Same question....?
I'd also like to speed up image processing in a similar manner pixel by pixel...?
I'm sorry blobul if you thought I had posted an answer!
Thank you
Same question....?
Thank you
Mega_bored - Posts: 4
Re: image dsp
There are various ways you could go. What is it you're trying to do? How are you doing it at the moment?
support - Posts: 151
Re: image dsp
Hi
This is my latest version.
It is by no means finished and requires other processing to convert RGB / alpha.
I would like to speed up the process of scanning the image at this stage.
Thanks
Thanks
Re: image dsp
Hello,
Downloaded a few times!!!
Any ideas for speeding up the image processing?
Thanks
Thanks
Re: image dsp
Fast C# library?
OpenCV, GD, ImageMagic,
you can integarte , with ruby and Win32API
- Tronic
Re: image dsp
Agreed Tronic...
Except go full blown C++ not C#, MS's half assed overhead crazy version C#...
- VPDannyMan
Re: image dsp
Thanks Tronic and VPDannyMan for your replies!
I'm not very familiar with programming PC apps. any recommendations for which route to take/learn and which software? C++, etc.
Any particular version of C++ or other software and from where can I download?
Thanks again
Thanks again
