pitch tracking and stability
Postby tester » Mon May 06, 2013 7:54 pm
I'm trying to get stable pitch tracking for low frequencies (40-300Hz) in order to monitor selected peaks above the fundamental (I'm using recent Martin's pitch tracking module). But no matter what I do - I can't stabilize the peak detection/appearance within detectable range (and accuracy). I don't know, maybe it should be different pitch detection method? (acceptable would be slower but more stable). Can someone help?
pitchtracking-low-freqs.fsm
(80.34 KiB) Downloaded 934 times
Re: pitch tracking and stability
Postby tester » Mon May 06, 2013 9:23 pm
I made a "smart" green buffer, that seems to do the job. However I don't know if this is the greatest idea. Or maybe it can be simplified?
pitchtracking-low-freqs-01.fsm
(80.62 KiB) Downloaded 969 times
Postby tester » Tue May 07, 2013 12:54 pm
Made different buffer.
buffer-v2.fsm
(403 Bytes) Downloaded 970 times
