MVerb 7 - yet another reverb?
Postby lalalandsynth » Sun Jun 02, 2019 12:13 pm
On Off animation.
Mverb On off.gif (37.98 KiB) Viewed 17472 times
lalalandsynth
Postby lalalandsynth » Sun Jun 02, 2019 12:26 pm
Maybe a custom dropdwn. Complicated but doable
Mverb 7 Custom Drpdwn.png (157.45 KiB) Viewed 17470 times
lalalandsynth
Postby lalalandsynth » Sun Jun 02, 2019 12:32 pm
Wonder if the Freeze should latch or be momentary
lalalandsynth
Postby lalalandsynth » Sun Jun 02, 2019 1:02 pm
Minor refinements and on off states for knobs switches.
proper state of orange strip on RT60 knob.
Mverb 7 Refinements.png (157.71 KiB) Viewed 17467 times
lalalandsynth
Postby Spogg » Sun Jun 02, 2019 1:32 pm
lalalandsynth wrote:Wonder if the Freeze should latch or be momentary
Right-click latch, left-click momentary?
Postby lalalandsynth » Sun Jun 02, 2019 2:30 pm
Yes, that would make sense, waiting for the go ahead from Martin before I start doing the animations . ;)
lalalandsynth
Postby lalalandsynth » Sun Jun 02, 2019 2:34 pm
oh crap....
I am working on the 64 bit Alpha version ... Well, everything works and its very stable .
So this version will be 64 bit.
lalalandsynth
Postby lalalandsynth » Sun Jun 02, 2019 3:41 pm
Getting somewhere , animation the circular orange thingies is a problem , will figure something out.
Mverb Switches.gif (134.67 KiB) Viewed 17460 times
lalalandsynth
Postby Spogg » Sun Jun 02, 2019 4:15 pm
lalalandsynth wrote:First Draft with one slider for wet-dry , added volume and a reverse function , mostly because i need to fill space :D
Maybe the “Reverse” button could determine whether the live input to the reverb is killed or not, when Freeze is ON? It would be nice to have both options I think.
Postby lalalandsynth » Sun Jun 02, 2019 4:46 pm
yes, will try that .
Managed to animate the circular knob ,was quite tricky masking work in After effects, well, for a novice like me anyways.
Circular animation.gif (301.08 KiB) Viewed 17458 times
lalalandsynth
