New LA Bands 2 EQ
• Page 2 of 2 • 1, 2
Re: New LA Bands 2 EQ
BTW, I had to look around for these peaking EQ filters by Michael Benjamin. I guess I had retrieved them from naiante.com.
These are by MJ and optimized by Michael Benjamin Voigt and Infuzion.
1156_PeakingEQ1.8MJasm.osm- Peaking EQ by MJ
- (111.13 KiB) Downloaded 1110 times
wlangfor@uoguelph.ca wrote:Halon wrote:Is this a clean eq or does it add color?
No colour, a smoothness though. I'm uploading the knob right now to the knobman gallery.
It's a bit heavy handed in the upper mids though. I might smooth that out in a small way.
I do like color and mojo though.
- Halon
I used to as well, but now I like sustained transients. Only achieved of course by properly calibrated attack and release. You know I realized that only Ruby was able to get euler's constant to work with that to any kind of exacting degree.
That Ruby example's in My Esquire Limiter. I find it useful but I'll be making another version that doesn't sound so "firm" and analog. I'll make the same limiter with a more relenting and airy release.
I achieve that by adding a gain rider. I'll add an exponential governor by calculating averages for varied benchmarks like -6 and -13. That way it still peaks beyond but it's averaged. I'm not a fan of brickwall limiters. They are sometimes nice with lofi samples and drums maybe though.
Here's a new track; it's eighties revival. Made with Bands 2 and the Esquire Limiter:
It's a big project though. months to master
EDIT: Halon, btw. This EQ of mine has all kinds of Colour:
http://dsprobotics.com/support/viewtopic.php?f=2&t=14696&p=54811#p54777
Just updated this EQ. It works faster and it uses less memory.
wlangfor@uoguelph.ca wrote:Here's a new track; it's eighties revival. Made with Bands 2 and the Esquire Limiter:
Thanks Robert. Will check out that eq
- Halon
Halon wrote:wlangfor@uoguelph.ca wrote:Here's a new track; it's eighties revival. Made with Bands 2 and the Esquire Limiter:
Yup, I just have to figure out an algorithm for making it quieter. Maybe My new zipper modification will be good for that.
[moderator comment:trog]
Some following posts have been split off into their own thread: Language Corrections
