Filters - Hop and No hop. What is the difference?
Postby Halon » Wed Jun 19, 2019 12:56 am
As the title says, What exactly is the difference?
Halon
Re: Filters - Hop and No hop. What is the difference?
Postby tulamide » Wed Jun 19, 2019 2:37 am
The number of samples processed. No hop means every sample is processed, hop(x) only processes every x sample. The cost is CPU load, the more samples processed the more accurate the result and the more work for the CPU.
Postby martinvicanek » Wed Jun 19, 2019 2:55 am
I would add that for filters usually only the coefficients update is hopped while the filtering itself is iterated at sample rate. This is justified in many cases because filter modulation is often much slower than the audio signal.
Postby Halon » Wed Jun 19, 2019 6:51 pm
Thanks guys for the explanation guys :)
Halon
Users browsing this forum: Google [Bot] and 82 guests
