GreySynth
GreySynth
Postby billv » Wed Aug 14, 2019 1:55 pm
Hey Guys, here's a new toy. Its got a bit of "X11" theme to it.
A basic synth with some mods, routing matrix and automation matrix.
There's 8 presets, so all you have to do is hit the start button. :)
[img]
[/img]
Grey Synth_v01.fsm
(1.48 MiB) Downloaded 1268 times
Re: GreySynth
Postby Phil Thalasso » Wed Aug 14, 2019 3:27 pm
Thank you Bill for sharing.
It looks very interesting and I'm sure that I will learn plenty by "dissecting" it.
Best Regards
Phil
Phil Thalasso
Re: GreySynth
Postby trogluddite » Wed Aug 14, 2019 3:34 pm
Wow, that's heaps of fun - and great to see the X-series still going strong. In a very good way, it makes me wonder what Tom and Jerry cartoons would be like if they'd been scored by the BBC Radiophonic Workshop. Maybe I'm not the only one around here who grins from ear to ear at vintage Dr. Who soundtracks instead of finding them scary? :? :lol:
Re: GreySynth
Postby Spogg » Wed Aug 14, 2019 5:00 pm
That’s excellent Bill!
I can see just how much work went into that and I’m very impressed. :ugeek:
I was wondering why the Preset Manager didn’t have the usual menu system. Do you rely purely on the DAW’s fxp and fxb system?
Also I feel I should mention that the first preset on loading was just into clipping on my system, but it took me ages to find the master volume control. Maybe it could be separate and bigger…?
This is amazing work and thanks so much for sharing it with us all.
Re: GreySynth
Postby billv » Wed Aug 14, 2019 11:28 pm
Thanks Guys.
Spoogg:
I made that Pre-set manager a few years ago.
It writes and reads to text file so nothing is required by the user.
So , while in your DAW , if you save a preset, it's there when you reload the vsti.
The "stock" preset manager is a bitch :evil: , and does not have this behavior.
Re: GreySynth
Postby RJHollins » Thu Aug 15, 2019 12:52 am
Tried to download and run .... got an 'Access Error'.
FS 3.07 Win-7[64]
Re: GreySynth
Postby billv » Thu Aug 15, 2019 4:00 am
I'm on XP...have no idea about the other platforms :?
Re: GreySynth
Postby trogluddite » Thu Aug 15, 2019 1:57 pm
RJHollins wrote:Tried to download and run .... got an 'Access Error'.
biilv wrote:I made that Pre-set manager a few years ago. It writes and reads to text file
billv wrote:I'm on XP.
I wonder if these might be related. I noticed that GreySynth automatically saves a small text file containing the current preset names at startup. For a plugin export, this gets saved in a 'GreySynth' folder alongside the plugin DLL; and from within FlowStone, it gets saved to the user's default VST export folder (wherever you last exported a VST plugin to, unless explicitly set by a 'VST Plugin Info' primitive in the schematic.)
Later Windows versions are far more fussy than XP about which folders applications are allowed access to, even if you're logged in as an Administrator, so this might be causing problems writing to the folder (or its parent folder may not exist). Everything works fine on my Windows 10 machine running FS 3.0.6, where I keep my shared plugins in a separate 'all-access' drive partition. However, the canonical VST plugins folder is usually somewhere within 'Program Files', to which access will be restricted.
To test this, here's a version which defaults to the schematic folder rather than the VST plugins folder when you're working within FlowStone (just one primitive added - a 'Schematic File Path' to set the 'Test' folder of the 'Start Folder' primitive within 'Preset Manager_BV/Save_Load/File save'.)
Grey Synth_v01_folder_path_mod_TROG.fsm
(1.47 MiB) Downloaded 1222 times
NB) This may not be a complete fix - it's just intended to test whether my hypothesis about the access error is right.
Re: GreySynth
Postby RJHollins » Thu Aug 15, 2019 4:30 pm
Hi TROG,
Just tried this test version. Still getting an Error Message: Here's the top snippet of the message.
caused an Access Violation (0xc0000005)
in module FlowStone.exe at 0023:005416ae.
Exception handler called in ExceptionAttacher.cpp - AfxWinMain.
I've no idea on this, and don;t think I've ever had this happen before.
Re: GreySynth
Postby trogluddite » Thu Aug 15, 2019 4:55 pm
Bugger! :cry:
That's something a little more serious, then. An 'Access Violation' means that FlowStone is trying to read or write to a memory address outside of the memory allocated to it by Windows (it quite often happens if code tries to read/write past the end of an array or string.) It might be possible to work out which component is causing it by a process of elimination, but really, I think MyCo is probably the only person with a good chance of getting to the bottom of it.
