Lfo in ruby
Re: Lfo in ruby
Postby borodadada » Sat Jun 22, 2013 6:08 pm
No stream, Green circle f :) float. Basic speed static.
demo version ^)
http://rghost.ru/46944750/image.png
borodadada
Re: Lfo in ruby
Postby Nubeat7 » Sat Jun 22, 2013 7:51 pm
:lol: hopefully you didn`t try my code example, i should try the next time.. here is something which works
thru_array.fsm
(427 Bytes) Downloaded 904 times
Re: Lfo in ruby
Postby borodadada » Sat Jun 22, 2013 8:38 pm
fantastic, thank you
but how change time ? ^)
speed = 0.1 not work :S
borodadada
Re: Lfo in ruby
Postby Nubeat7 » Sat Jun 22, 2013 10:52 pm
itsbecause time % size is the index for the array and this counts only the full numbers - with a speed of 0.1 it is counting 1,1.. 1.2... 1.3... and so on so it counts every 10 steps... just multiply the time with 10 before you do the modulo... or 100 when speed is hundreth...
Re: Lfo in ruby
Postby borodadada » Sun Jun 23, 2013 6:27 am
def event i,v,t
v=*(1..1000)
a=*(2..999)
a.reverse!
va = v+a
size = 1998 #arraysize
speed = 0.0101
c = time * 1000
if @on
output 0, va[c%size]
input 100, nil, t + speed
Okey.... modify, work.
Thanks!
borodadada
