Req: Text Viewer in ruby with scroller
Re: Req: Text Viewer in ruby with scroller
Postby wlangfor@uoguelph.ca » Sat Aug 24, 2019 6:12 pm
Nubeat7 wrote:here is an updated version, which doesn't use the setViewSize methode (so it should work with fs 3.04 too), the maximum text area is the size of the text window, i think this is a better solution for it anyway because like this you don't need to change the max text area at the stringMeasure methode,
i also integrated a properties panel where you can set textsize, font, margins and colors...
This is quite impressive, thanks.
My youtube channel: DSPplug
