Controller Xbox360
Re: Controller Xbox360
Postby Almeida » Tue Jul 23, 2013 7:59 pm
i have doing this but its about a windows program which open twenty windows with different name each time.
Thx you
Almeida
Postby digitalwhitebyte » Tue Jul 23, 2013 8:39 pm
Your request at this point does not seem to be inherent to Flowstone. ;)
If you explain better what you need to do, we can help the same, but without knowing what your intent is difficult.
digitalwhitebyte
Postby Almeida » Tue Jul 23, 2013 11:24 pm
i' m simply searching to do the same like AHK :
Right::
WinGetActiveTitle, Title1
WinMove, %Title1%,, 938, 10
cause i can move the active window without needing the window' s name. i cant know names of windows before. Sometimes they are call Hamburg 6, Hamburg 7, Tokyo 2, Tokyo 3, etc,
I hope I was clear in my explanations,
Cheers.
Almeida
Postby MyCo » Wed Jul 24, 2013 12:44 am
Move Active Window (MyCo).fsm
(937 Bytes) Downloaded 1539 times
Postby Almeida » Wed Jul 24, 2013 11:56 am
this is exactly what I was looking.
Thanks for help
Almeida
Postby jjs » Mon Jul 29, 2013 8:58 am
i use this for a standalone program.
it is not as nice as having something internal which could take care of it.
Because now an external little program is called, and you always have to check if it is in the right place.
But it works.
I had it from someone else i can't remember but it is somewhere here on the forum allready.
move position.zip
(686.61 KiB) Downloaded 1574 times
jjs
