Last Switch(Ruby)
Last Switch(Ruby)
Postby billv » Mon Aug 05, 2013 7:47 am
Had lots of silly attempts at this over last few weeks...
have stripped it down to this....
def event i,v
  if i==0 then
  output 0,@firstsignal
  if i==1 then
  output 0,@secondsignal
I want it to behave just like the standard "green" Last Switch.
Seems to work right...but it's a real important part...and I've stuffed it up a few times now...
so I want to make sure...before i stick a few hundred in my schematic..
Can anyone see a problem with this code....??
Is there a better way...?
Re: Last Switch(Ruby)
Postby MyCo » Mon Aug 05, 2013 8:03 am
def event(i,v)
  output(v)
Postby nix » Mon Aug 05, 2013 8:21 am
I think the inputs will sum MyCo?
Bill, I have done exactly the same thing,
I think it works fine.
nix
Postby billv » Mon Aug 05, 2013 8:35 am
Great.....thanks guys.
Postby MyCo » Mon Aug 05, 2013 5:16 pm
nix wrote:I think the inputs will sum MyCo?
No, why should they?
Postby billv » Mon Aug 05, 2013 8:43 pm
Works great Myco....
I thought the inputs would needed to be declared individually....
I had no idea i could get away with that.. :D
Postby nix » Mon Aug 05, 2013 10:37 pm
oh ok sorry-
I don't know what i was thinking there
That's neat as MyCO, will use it too
nix
Postby RJHollins » Tue Aug 06, 2013 8:50 am
Ahhh ... for the 'slow' learner crowd ... apparently me :o
I tried a very simple input [ 0 or 1], along with inputs for the the 2 variables ... I could not get this to work consistently :shock:
This seems that this should be a simple choice and path through the code ... If 'this' ... this, if 'that' .... that.
How I'm screwing this up is ridiculous .... I'm embarrassed, but can someone shed light on this please :oops:
Thanks.
:roll:
Postby nix » Tue Aug 06, 2013 12:16 pm
last.fsm
(524 Bytes) Downloaded 944 times
Here are 3 variations, 2 of Bill's and the MyCo one.
I think the problem u had was not naming the inputs.
np with asking- it's how I finally cottoned onto this program a little
nix
Postby RJHollins » Tue Aug 06, 2013 6:40 pm
Thanks Nix !!
It was the 'Trigger' :shock:
I had mine similar to your 2nd example ... BUT ... I also had a 3rd INPUT variable (i). :roll:
Obviously, still struggling to get a handle on the basics of RUBY. I'm hitting those posted RUBY sites to get familiar. My only programming 'experience' was using GFABasic on the ATARI ST back in the 80's. :lol:
When I looked at this "Last Switch', I saw an input [i], and 2 result variables. So on the left side of the RUBY box, I had 3 string inputs [labeled] ... i, firstsignal, secondsignal. I thought changing i from 0 to 1 would toggle the output through the IFTHENELSE routine.
Still don;t understand why this didn't work ... also [now] not sure what the 'DEF event i,v' is really doing. I thought this was telling RUBY to watch for 'i' and output to 'v'.
ahhh ... soooo much more to learn.
Users browsing this forum: No registered users and 25 guests
