need some help peeps. Rompler doesent hold the files i used
Re: need some help peeps. Rompler doesent hold the files i u
Postby djbrynte » Fri Aug 16, 2019 4:04 pm
i solved the problem i found the folder now everythign works thanks anyway
djbrynte
Postby djbrynte » Thu Aug 29, 2019 8:09 am
I get an error message when loading the samples in a folder when using this. the one u fixed spogg :/
djbrynte
Postby wlangfor@uoguelph.ca » Mon Sep 02, 2019 4:17 pm
djbrynte wrote:I get an error message when loading the samples in a folder when using this. the one u fixed spogg :/
I'll look too. Not saying I'll fix it for sure, but I will look.
My youtube channel: DSPplug
Postby djbrynte » Mon Sep 02, 2019 9:57 pm
Would be awesome if you could fix it so we have a working rompler.
djbrynte
Postby wlangfor@uoguelph.ca » Tue Sep 03, 2019 3:22 am
djbrynte wrote:Would be awesome if you could fix it so we have a working rompler.
true true. I used to be some programmer, maybe I can after all maybe. Compared to php it's not all that hard I guess.
Postby wlangfor@uoguelph.ca » Tue Sep 03, 2019 3:13 pm
working on this today.
Postby wlangfor@uoguelph.ca » Wed Sep 04, 2019 3:06 am
OK, so I tried with .6 .8, fl studio version and beta 9.1, 9.2 and it doesn't load at all. Do you have a basic version that works in 0.6 or 0.8? Just give Me that and tell Me what you want it to do. And that's what I'll do.
Postby djbrynte » Thu Sep 05, 2019 9:39 pm
SPOGG is godfather :)
djbrynte
Postby wlangfor@uoguelph.ca » Fri Sep 06, 2019 2:13 am
djbrynte wrote:SPOGG is godfather :)
Well, I've refused his offers in the past and still breathing, just saying.
Postby kortezzzz » Sat Sep 21, 2019 7:16 am
Here is the fix.
LEGAL VST rompler 4 kortezzzz fix.fsm
(585.3 KiB) Downloaded 1410 times
kortezzzz
