Rectangle & Ellipse Module in Ruby
Postby chackl » Wed Aug 21, 2013 8:50 pm
Hello!
Today a was making some GUI in ruby and as a "Lession" i did a port of the old Rectangle & Ellipse Modules from Synthmaker V3 / FlowStone V2
As you see i also did properties for config
What is new is the Hatch-Brush.
If you have any ideas for updates/upgrades please write here ;)
Base-Module - Free4Use in any Project.
For all Ruby nerds - please take a look how i did port all variables from te properties to the main module - maybe there is a better solution - if someone could do that ;)
Best Regards
rect&ell_v1.1.fsm
(5.32 KiB) Downloaded 1458 times
chackl
Re: Rectangle & Ellipse Module in Ruby
Postby Jay » Wed Aug 21, 2013 9:15 pm
very nice m8! cheers for these they will come in really handy! more please! :)
Best Regards
Jay
Postby RJHollins » Thu Aug 22, 2013 6:27 am
Very nice modules and coding chackl !
Thanks for sharing your work. These are items needed for most any project.
Thanks again !!
8-)
Postby billv » Thu Aug 22, 2013 7:54 am
Very handy at the moment...Thanks for sharing.
Cheers.
Postby trogluddite » Thu Aug 22, 2013 11:11 am
Hi chackl - nice stuff, bringing some of the new Ruby graphics options to a simple module. :)
Here's my version of the "options hasher". The @vals data is stored using the saveState/loadState methods, so there's no need for the 'input scanner, so there are far fewer events and triggers kicking about...
Options Hasher.fsm
(1.31 KiB) Downloaded 1540 times
PS) Ruby instance variables (NOT local variables) can always be read, even before they are declared - returning nil if undefined. And there is a shorthand method for testing nils, ".nil?"
So...
defined?(@vars) == nil
...can be simply written as...
@vars.nil?
The "||=" that's used in my code is also very handy in situations like this. It's usually known as "OR-equals" - if the variable is undefined, nil or false, it gets assigned the right hand value, otherwise the old value is kept. Just take care if the variable is holding a boolean (true/false) value, though, as 'false' would be overwritten!
Postby chackl » Thu Aug 22, 2013 12:01 pm
Thanks for the example i'll update it within the next version :D
And thanks for the little ruby lesson :D - I've just began to understand ruby and i'm now experimenting with custom objects and classes.
Thank you :D
chackl
Postby billv » Thu Oct 31, 2013 5:18 am
@chackl..... may have a little bug...
if change fill style to 'solid'
.no color changes possible.... no hatching either... ??..
Postby nix » Thu Oct 31, 2013 5:36 am
love the hatching brushes mr. Hackl
is it possible somehow to define the size of the hatches?
nix
Postby chackl » Tue Nov 05, 2013 1:20 pm
nix wrote:love the hatching brushes mr. Hackl
Thanks ;)
Well i did not find anything - if someone finds a metode i can add it ;)
chackl
Postby chackl » Tue Nov 05, 2013 1:22 pm
billv wrote:@chackl..... may have a little bug...
Well a hatch allways needs 2 colors ;)
So Hatch is an addition to solid/Linear/Radial.
chackl
