Random Number Limit?
Postby Dugg Funnie » Tue Sep 03, 2013 3:46 pm
hey everybody, first post! woohoo!
So, I'm working on a plug-in that will randomly load two effects and assigned parameters to an XY pad. Here's the issue I'm running into:
I have a Random prim that's time seeded and using an AfterLoad prim to trigger the generation (and thus the FX selection/assignment) when the plug-in is loaded. However, I'll only have a grand total of 12 effects to choose from, and given that the random prim generates 0-32767, a good percentage of the time it ends up just loading the last plug-in in the Selector's index. So, what can I do to limit the Random's range to something like 0-12 or anything like that?
Dugg Funnie
Re: Random Number Limit?
Postby CoreStylerz » Tue Sep 03, 2013 4:03 pm
Try this.
But is an workaround. :lol:
Seed max to 12.fsm
(386 Bytes) Downloaded 912 times
PM me if you are interested.
CoreStylerz
Postby trogluddite » Tue Sep 03, 2013 8:46 pm
Much easier to use Ruby.
The randomness is automatically time/process seeded, and to get a random number 0-11 (assuming the FX are zero indexed), you need just one line...
output rand(12)
Yup, that's it, just paste that into a Ruby box and change the input to a trigger and the output to an integer - done!
Postby MyCo » Tue Sep 03, 2013 9:21 pm
Reduced Rand (MyCo).fsm
(257 Bytes) Downloaded 857 times
Postby Dugg Funnie » Fri Sep 06, 2013 6:24 pm
/\ Wow. That was simple! Thanks!
Dugg Funnie
