difference between optimization of filters
Postby tester » Fri Sep 06, 2013 8:40 pm
MyCo - what did changed (in terms of differences produced by audio output) in optimizations you did on this filter pack? Or is this 1:1?
source filters (Complete Dozius Filter Pack):
http://synthmaker.co.uk/forum/viewtopic ... 564#p59720
your mods:
http://synthmaker.co.uk/forum/viewtopic ... =15#p70109
I'm gathering a package of filters (for a project) that would produce good output when used with modulators and noises.
Re: difference between optimization of filters
Postby MyCo » Sat Sep 07, 2013 2:21 am
I wrote it in the post:
I removed the samplerate parts and some useless multiplications from the Linkwitz-Riley filter.
I'm getting old, can't remember much from that time... 3 Years ago...
Postby tester » Sat Sep 07, 2013 10:08 am
:mrgreen: I guess we are in the same or similar age.
I asked, because looking at the codes - I can't tell whether it was added something "obvious not worth to mention" (denormals algos?) or changed something that will produce different rounding (thus - audible results if these variations play the role).
Doing side by side audio comparisons, I had the impression that at least one of these filters sounded a little bit different (gain + something). But maybe I was tired - will check on this one later.
Postby tester » Sun Sep 08, 2013 6:33 pm
...and now the best part. i just realized, that I was watching at totally different filters, made and optimized by someone else :mrgreen: :mrgreen: :mrgreen:
http://synthmaker.co.uk/forum/viewtopic ... a&start=30
I'm trying to figure out what is the relationship between provided "slope" and real resonance "Q" in shelf filters...
Postby Father » Sat Oct 24, 2015 4:34 am
I've used a SVF lp filter optimized by myco on left and right channels, and it creates stereo artifacts (mono source). Seems a bit of precision has lost with optimization, am i right?
Father
Postby RJHollins » Sat Oct 24, 2015 4:45 am
could it be a 'timing' difference between the 2 codes running ?
Postby Father » Sat Oct 24, 2015 5:08 am
RJHollins wrote:could it be a 'timing' difference between the 2 codes running ?
Solved:
MyCo uses a hop(128) on a part of the code. Its a bit high so I set it to 8 and you can't hear any annoying effect by ear.
Father
