Draw Wave Min/max Control issue
I'm having trouble getting control of min/max ranges for the Draw wave......
That green section in Draw wave is still too tricky for me....
When I built my first matrix trigger that green section done my head in...
....nothings changed...
Have made a clear fsm to show the issue....
Re: Draw Wave Min/max Control issue
billv wrote:I'm having trouble getting control of min/max ranges for the Draw wave......
would be another cool oneliner in ruby:
#inputs: @arrayIn, @min, @max
output 0, @inArray.map!{|item|[[item,@min].max,@max].min}
#do anything with item between |item|......}
note here you just limit the values to max and min!
there you would change the range:
output 0, @inArray.map!{|item|item*@max-@min+@min}
also note, when you directly return the modified arrayvalues, you need to use the "!" after map, in this case the original array was modified (destructive)
if you put the modified values into a new array u can use just "map" with out the "!" so the original array stays untouched
Thanks nubeat7....but i keep getting method error for map!...
changing code from '@inArray.map!' ...to. '@arrayIn.map!' didn't work also...
Writing the min max part will be ok, the problem is that the min/max parameters
are tied to the graphics, so it becomes a lot more complicated....
Probably scrap the idea.......
you don`t need event..
and sure, dont send the modified values to the graphics just send them towhere you need them
Draw wave min_max.fsm- (5.89 KiB) Downloaded 962 times
here you keep the original array untouched, i wrote a little class array methode for easy use of the methode
edit: maybe the methode should better be named "set_to_range"
taking a look now......
This mod is for the "Array tool" i made....
Will upload to examples so you can see the whole thing...
Nubeat7 wrote:you don`t need event..
Yeh..it goes...i figure the error was using string array input instead of float array?
...controlling min/max either side of draw module is not a issue for this circuit....
Need to control the draw module min/max parameters directly...
I don't think this mod can happen otherwise ...
billv wrote:Need to control the draw module min/max parameters directly...
if you want to change the draw min/max you can use "range" inside the properties of the wavedraw module, but when bigger than 1 you will draw outside viewrange
