WinXP - Win 8 --- something I need to know ?!?
Re: WinXP - Win 8 --- something I need to know ?!?
RJHollins wrote:What da heck do you mean ??? I'm right now trying to figure out some kind of test app that I could write to see how to fix this.
That's exactly what I mean..
with a special appeal to vista,7,8 users...I'm on XP and can't help here..but others could...
RJHollins wrote:May an Angel take pity.
Hang in there mate... I think you done a great job absorbing Trogs advice so quick....
always takes me about 3 months to start understanding what he's telling me..
Billv ...
I just let Trog THINK that I'm able to follow him !!!
He is very sensitive you know
Honestly, I've been 'left in the dust' from several of you guys !
anyway ... back to this serious issue.
I've been trying to think of a test to do ... it would seem it must be a VST as the stand alone seem to slip by [for whatever reason I can't understand] ... the GOOD thing is, this MAY support the notion that my coding is not the cause [I do reserve the right to be proven wrong]
As to a test ... for one, I've not heard back the status of the Preset manager writing/reading. If that thing works without issue ... then something else is not right
Drnkn just posted that he is finding 'permissions' both the cause and the solution. This definately helps define things.
My real hope ... the safe-haven to write/read a txt file. Since we are both
XP ... there's not much to test. Somebody with a newer system must have something going ??? otherwise, wouldn't we hear something !!
OK .. a test module ... I'll try to think of something that would alert the problem ... but I'm not sure how to make it so that we can easily test for a solution
Can the SYSFolder [ENV variable] be modified in real time ?? I don't know
That about the only PRIM I know of that could be used.
The RUBY stuff I posted where stuff from other DEVs ... I yield to the experts here on that.
Right so here is a test module, VERY basic but should give us an idea if it works on all our systems.
Im on Win7 32bit BOOTCAMP & I have no probs. Writes & reads the file.
I tested on my win8 64bit laptop & also no problems.....anyone else wanna try?
- Drnkhobo
Drnkhobo wrote:...anyone else wanna try?
i`ll try it on my 2 win7 64 bit laptops this evening...
Drnkhobo wrote:Right so here is a test module, VERY basic but should give us an idea if it works on all our systems.
It will work but add an afterload trigger to ensure that the path is updated.
Mo - Posts: 17
Updated the schm. . . but doesnt it update anyway during load? - No harm in being sure
- Drnkhobo
I'll be testing too ..and send out to my tester.
One thing ...
the VST format needs verification too !
I have found the EXE to work, but VST fail [with my current project] on Win7/8. yet work on XP.
VST may have external conditions [host] that could cause problems. So testing both formats is vital.
One thing ...
the test schematic from drnkhobo works here on both laptops win7 64 bit in cubase5.5 32bit and renoise 2.8 32 bit
ps: tested as vst fx
Nubeat7 wrote:the test schematic from drnkhobo works here on both laptops win7 64 bit in cubase5.5 32bit and renoise 2.8 32 bit
Both EXE and VST flavors ??
