Toggle and Flip-Flop module
Postby arend » Fri Sep 23, 2011 7:39 pm
Simple but useful, why are not listed as primitives ?
Toggle: alternates the logic output after each trigger.
toggle.fsm
Toggle
(291 Bytes) Downloaded 2137 times
Flip-Flop: a logic memory, with set and reset
FLIPFLOP.fsm
Flip-Flop
(413 Bytes) Downloaded 2093 times
arend
Re: Toggle and Flip-Flop module
Postby Morph » Fri Sep 23, 2011 7:45 pm
You can find something similar in the switch. Also the last "Not" in the toggle seems not to be needed.
Cheers.
Morph
Postby arend » Fri Sep 23, 2011 8:29 pm
The last '"NOT" is just for initializes the output module w/ "0'" logic.
brgds
arend
Postby DSP » Sat Sep 24, 2011 12:07 pm
Here's an alternative Flip-Flop that is simpler and safer.
FLIPFLOP-2.fsm
(535 Bytes) Downloaded 2050 times
DSP
Postby arend » Sat Sep 24, 2011 7:59 pm
DSP,
Understood, tks !
brgds
arend
Postby fixstuff555 » Wed Sep 28, 2011 1:45 am
DSP wrote:Here's an alternative Flip-Flop that is simpler and safer.
Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
fixstuff555
Postby DSP » Fri Sep 30, 2011 3:57 am
fixstuff555 wrote:Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
Indeed, I am also a beta tester!
DSP
Postby fixstuff555 » Sat Oct 01, 2011 2:48 pm
Sweet... Can't wait to see it!
fixstuff555
