MouseCursor Position
Postby billv » Thu Oct 24, 2013 11:49 pm
The default FS knob behaviour is not good for fast tweaking..... :evil:
Start at 0 ...go all the way to 1...and your mouse cursor ends up
4 inches up the screen.... :roll:
So I just need to put the original cursor position back in when the mouse goes up...
But having trouble trying to write it in...
Should it look something like this...
def mouseCursor x,y
if i == 1 or 2 then
mouseCursor.pos = @inputx,@inputy
Re: MouseCursor Position
Postby billv » Fri Oct 25, 2013 11:52 am
How do you control cursor position without using the cursor...?
Is possible..?...
Postby Nubeat7 » Fri Oct 25, 2013 5:02 pm
why not using the show cursor primitive? you can set "hold position while dragging"
Postby billv » Fri Oct 25, 2013 10:02 pm
Nubeat7 wrote: "hold position
Thanks Nubeat7....didn't notice that...
Postby strangeChild » Sat Oct 26, 2013 7:42 am
billv wrote:So I just need to put the original cursor position back in when the mouse goes up...
That was the default behaviour with SynthMaker stock knob... I say it should be for FS too.
SynthMakerKnob.fsm
(131.65 KiB) Downloaded 952 times
strangeChild
Postby strangeChild » Sat Oct 26, 2013 5:11 pm
Is there a Ruby method available to set the cursor position? :?
strangeChild
Postby strangeChild » Sat Oct 26, 2013 5:16 pm
Nubeat7 wrote:why not using the show cursor primitive? you can set "hold position while dragging"
Ah! I didn't get this right away...
Still... is there a Ruby method for setting the cursor position?
strangeChild
