IfThenElse STREAM COMPARATOR TRANSLATOR
Hello all,
Here is a IfThenElse STREAM COMPARATOR TRANSLATOR
I did not understand the dsp mono code, as I am more into signals and not well versed in much code at all.. So I made this translator. Just fill in the title of each variable, choose your comparison operation, then copy and paste the line of code into your corresponding dsp code box.
Unnecessary? Efficient? Redundant?
You be the judge !
~ That Guy
ps. maybe you good at ruby and make ruby version? improvements?
You be the judge !
~ That Guy
guyman - Posts: 207
Re: IfThenElse STREAM COMPARATOR TRANSLATOR
I'll check it out thanks
