Flowstone 3.0.4 Released
• Page 2 of 2 • 1, 2
Re: Flowstone 3.0.4 Released
I noticed some "glitches" in saving performance (sometimes slower saving; maybe because of updates from previous version). Nothing big, although within big projects (3-5MB, pure prims/coding, no large arrays/bitmaps inside, over 500k connections) with many synced modules. I don't know, maybe because saving was always slower here? But not not minutes.
To consider - some sick interaction with antiviral software. Temporal turn off.
To consider - re-copy modules and save within new project; maybe something is/becomes corrupted?
To consider - test what sort of modules or internal content is causing that. (audio during save is on? off?)
Question on the new DLL feature. How efficient is this when processing compared to Ruby? Also .. you can make DLL's in languages other then C/C++ .. can I use another language or only C/C++?
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
Attic - Posts: 30
Uh, oh.. My update support expired on 06-Dec-13
I knew this had to happen.. an update just under a week after my support ended
- matti
Maybe it's a good idea to contact devs directly for this update?
I would consider this.
Earlier version (3.03) introduced major bug - CPU overload in idle mode; horror for laptops...
3.03 projects often will/may not open correctly in version 3.02 due to changes.
Version 3.04 fixes CPU bug.
...which means it would be fair and logical if they support you.
Worth to try?
Worth to try?
I tried looking for the release notes and could not find them.. Where are they. (I know they said they were on the download page, I did not see them.)
- VPDannyMan
Sorry, never mind I found it at the top of the page..
- VPDannyMan
